Asp.Net Hata Alıyorum
    Blackfire
    Blackfire's avatar
    Kayıt Tarihi: 06/Temmuz/2008
    Arkadaşlar yaptığım projeyi publish edip ftpye attım iki yerde sıkıntıyla karşılaşıyorum 1. resim yüklerken hata alıyorum 2. hata logları tutuyorum onları oluşturacağı zaman da hata veriyor sebebi nedir acaba yardımcı olabilirmisiniz
    Verdiği hata bu
    Server Error in '/harun.aydin' Application.
    Could not find a part of the path 'C:\Staj\Logs\log(17.05.2012_23.18.33).txt'.
    Description: An unhandled exception occurred during the execution of the current web request. Please review the stack trace for more information about the error and where it originated in the code.
    Exception Details: System.IO.DirectoryNotFoundException: Could not find a part of the path 'C:\Staj\Logs\log(17.05.2012_23.18.33).txt'.
    Source Error:
    An unhandled exception was generated during the execution of the current web request. Information regarding the origin and location of the exception can be identified using the exception stack trace below.
    Stack Trace:
    [DirectoryNotFoundException: Could not find a part of the path 'C:\Staj\Logs\log(17.05.2012_23.18.33).txt'.]
       System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath) +224
       System.IO.FileStream.Init(String path, FileMode mode, FileAccess access, Int32 rights, Boolean useRights, FileShare share, Int32 bufferSize, FileOptions options, SECURITY_ATTRIBUTES secAttrs, String msgPath, Boolean bFromProxy, Boolean useLongPath) +1142
       System.IO.FileStream..ctor(String path, FileMode mode, FileAccess access, FileShare share, Int32 bufferSize, FileOptions options) +82
       System.IO.StreamWriter.CreateFile(String path, Boolean append) +55
       System.IO.StreamWriter..ctor(String path, Boolean append, Encoding encoding, Int32 bufferSize) +121
       System.IO.StreamWriter..ctor(String path, Boolean append) +33
       Library.HataLog.LogKayitEt() in c:\users\harun aydin\documents\visual studio 2010\projects\Library\Library\HataLog.cs:19
       Library.KitapEkle.Btn_Yukle_Click(Object sender, EventArgs e) in c:\users\harun aydin\documents\visual studio 2010\projects\Library\Library\KitapEkle.aspx.cs:40
       System.Web.UI.WebControls.Button.OnClick(EventArgs e) +118
       System.Web.UI.WebControls.Button.RaisePostBackEvent(String eventArgument) +112
       System.Web.UI.WebControls.Button.System.Web.UI.IPostBackEventHandler.RaisePostBackEvent(String eventArgument) +10
       System.Web.UI.Page.RaisePostBackEvent(IPostBackEventHandler sourceControl, String eventArgument) +13
       System.Web.UI.Page.RaisePostBackEvent(NameValueCollection postData) +36
       System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint) +5563
    Version Information: Microsoft .NET Framework Version:4.0.30319; ASP.NET Version:4.0.30319.272
    override
    override's avatar
    Kayıt Tarihi: 15/Aralık/2009
    2. log path in local deki kalmis path i server kodlarilariyla olusturmalisin
    1. dizin izinlerini kontrol et
    g͇̫͛͆̾ͫ̑͆l͖͉̗̩̳̟̍ͫͥͨ
    Blackfire
    Blackfire's avatar
    StreamWriter str = new StreamWriter(HttpContext.Current.Server.MapPath("../Logs/log(" + tarih + "_" + zaman + ").txt"), true);
    log tuttum yer bu kod nasıl localdeki kalıyoki elle tam bir dizin girmiyorum ki aslında
    ResimUrl = "KitapResim/" + DateTime.Now.Year + DateTime.Now.Month + DateTime.Now.Day + DateTime.Now.Hour + DateTime.Now.Minute + DateTime.Now.Second + FU_UrunResim.FileName;
    FU_UrunResim.SaveAs(Server.MapPath("../") + ResimUrl);
    Bu da resim yüklediğim yer izinler 666 iki klasör için de ama nerde hata yapıyorum anlamadım localde sıkıntısız çalışıyor
    Blackfire
    Blackfire's avatar
    up
    NuLL29
    NuLL29's avatar
    Kayıt Tarihi: 09/Temmuz/2007
    ../ bunu yazma.
     KitapResim ve Logs klasörlerinin oluşturulmuş olmasına dikkat et.
    edit şurada ne yapmaya çalıştın anlayamadım
    .::::Tesadüfen Doğdum Mecburen Yaşıyorum Zorudan Ölücem:::...
    Blackfire
    Blackfire's avatar
    NuLL29 bunu yazdı:
    ../ bunu yazma.
    ../ iki türlü de denedim bi sonuca ulaşamadım Klasörler de en baştan beri oluşturulmuş şekilde deniorum.
    log(" + tarih + "_" + zaman + ").txt") burada log dosyasının ismini tarih_zaman şeklinde oluşmasını sağlıyorum.
    NuLL29
    NuLL29's avatar
    (" ") bunları neden yazdın? Şöyle yap
    StreamWriter str = new StreamWriter(HttpContext.Current.Server.MapPath("~/Logs/log " + tarih + "_" + zaman + ".txt"), true);
     FU_UrunResim.SaveAs(Server.MapPath("~/" + ResimUrl);
    ../ yerine ~/ kullan
    Blackfire
    Blackfire's avatar
    NuLL29 bunu yazdı:
    Çok saolsın hocam ../ yerine ~/ koyunca düzeldi bütün sorunlar
    NuLL29
    NuLL29's avatar
    kolay gelsin;)
Toplam Hit: 1821 Toplam Mesaj: 9
