linefolder Skype - Mirc - Irc - Icq - Mail Güvenliği
linefolder MSN / Hotmail Kullanıcı Adı Kontrol Programı Kodu (Hotmail Checker)
    Nuker
    Nuker's avatar
    Kayıt Tarihi: 09/Ekim/2005
    [code];Author: nuker
    ;Contacts: ICQ: 10072 MSN: nukedx@nukedx.com
    ;Credits: WW xT Pepe and all my friends.
    ;Info: This code has been publiced by me and use it for only EDUCATIONAL purposes.
    on *:sockopen:msnc_*:{
      if (!$sockerr) {
        if ($lines(mssource.txt) == 0) { .sockclose $sockname }
        if ($lines(mssource.txt) > 0) { setmsn $sockname | .mspost $sockname $readini(msn.conf,stats,$sockname) }
    on *:sockread:msnc_*:{
      if ($sockerr) { .echo -a An error occuried }
      sockread $sockbr %msdata
      if ($msexist isin %msdata) {
        if ($msresult(%msdata) == $xdata($_memberexist)) {
          .write msbad.txt $readini(msn.conf,stats,$sockname)
          .msclose $sockname
        if ($msresult(%msdata) == $xdata($_memberforbid)) {
          .write msforbid.txt $readini(msn.conf,stats,$sockname)
          .msclose $sockname
        if ($msresult(%msdata) == $xdata($_membererror)) {
          .write mserror.txt $readini(msn.conf,stats,$sockname)
          .msclose $sockname
        if ($msresult(%msdata) == $readini(msn.conf,stats,$sockname)) {
          .echo -at $readini(msn.conf,stats,$sockname) alınabilir..
          write msgood.txt $readini(msn.conf,stats,$sockname)
          .msclose $sockname
    on *:sockclose:msnc_*:{ .sockclose $sockname }
    alias -l _memberexist { .return ,365M8F5R17AI<W1S```` }
    alias -l _memberforbid { .return -1F]R8FED9&5N5V]R9``` }
    alias -l _membererror { .return *3W1H97)%<G)O<@`` }
    alias -l xdata { .return $_nxdec($1) }
    alias -l _nxdec { .return $decode($1) }
    alias -l msresult { .return $remove($1,$msexist,$msgre) }
    alias -l msgre { .return ; domain=account.services.passport.net;path=/;version=1 }
    alias -l msexist { .return Set-Cookie: MSPMemberExists= }
    alias -l getdate { .return $+($ctime,$right($ticks,3)) }
    alias -l msclose { .sockclose $1 |   }
    alias mscheck {
      .remini msn.conf Stats
        .timercheckmsn 0 0 mssockets
        .unset %mslimit
        .set %mslimit $1
        var %msmk = 0
        var %msmklim =  $1
        goto msstart
        :msstart
        inc %msmk
        if (%msmk > %msmklim) { .goto end }
        .sockopen $+(msnc_,%msmk) accountservices.passport.net 80
        if (%msmk <= %msmklim) { .goto msstart }
        :end
    alias mssockets {
        .writeini msn.conf Configure status finish
        .timercheckmsn off
        .goto end
        .var %sockx = 0
        goto checkmsn
        :checkmsn
        inc %sockx
        if (%sockx > %mslimit) { .goto end }
        if ($sock($+(msnc_,%sockx),0) == 0) && ($lines(mssource.txt) >= %sockx) { .sockopen $+(msnc_,%sockx) accountservices.passport.net 80 }
        if (%sockx <= %mslimit) { .goto checkmsn }
      :end
    alias -l setmsn {
      if ($read(mssource.txt,1) !== $null) {
        .writeini msn.conf Stats $1 $read(mssource.txt,1)
        .write -dl1 mssource.txt
      if ($read(mssource.txt,1) == $null) {
    alias -l msexpire { .return Fri, 31 Dec 1970 23:59:59 GMT }
    alias -l mspost {
      if ($sock($1,0) !== 0) {
        sockwrite -n $1 GET /memberexists.srf HTTP/1.1
        sockwrite -n $1 Accept: image/gif, image/x-xbitmap, image/jpeg, image/pjpeg, application/x-shockwave-flash, */*
        sockwrite -n $1 Referer: https://accountservices.passport.net/reg.srf
        sockwrite -n $1 Accept-Language: tr
        sockwrite -n $1 Content-Type: application/x-www-form-urlencoded
        sockwrite -n $1 Accept-Encoding: gzip, deflate
        sockwrite -n $1 User-Agent: Mozilla/4.6 [en] (Win $+ $os $+ ; I)
        sockwrite -n $1 Cookie: $+(MSPMemberExists=,$2,;) domain=account.services.passport.net
        sockwrite -n $1 Host: account.services.passport.net
        sockwrite -n $1 Content-Length: 15
        sockwrite -n $1 Connection: Keep-Alive
        sockwrite -n $1 Cache-Control: no-cache
        sockwrite -n $1
        sockwrite -n $1 $+(x=,$getdate)
        sockwrite -n $1 $crlf
    }[/code]
    Bu bir mIRC scriptidir socket kullanarak Hotmail/MSN kullanıcı adlarını kontrol eder.
    Bu kodu mIRCinize yukleyip statuse /mscheck BağlantıSayısı yazmalısınız.
    Listenizin x@hotmail.com x@msn.com ve x@msndomaini seklinde olmasına dikkat edin
    Listenizi mIRC klasorunuze kopyalayıp isminin mssource.txt olduğuna dikkat edin çünkü kod o dosyadan okuyarak kullanıcı isimlerini tarayacaktır.
    Alınabilir kullanıcı adlarını X:\mIRC klasoru\msgood.txt dosyasında bulabilirsiniz.
    Ayrıca mevcut yasaklı ve hatalı kullanıcılar bu dosyalara çıkarılmaktadır > msbad.txt msforbid.txt ve mserror.txt!..
    PS: Kodumu editlemeyin! Aşağıdaki açıklamayı kullanarak kendi kodunuzu yazabilirsiniz.
    [code]Soru:Nasıl bir hotmail/msn kullanıcı adının mevcut olup olmadığını kontrol ederim.
    Hotmail kendi "reg.srf" sayfasındaki mantığı aynen kullanarak elbet
    Öncelikle bir socket açıp onu accountservices.passport.net:80 adresine bağlıyoruz ve aşağıdaki HTTP protokol kodunu yazdırıyoruz.
    --code--
    $getdate { .return $+($ctime,$right($ticks,3)) } ;; like 1128026182560 <- UNIXTIME
    Accept-Language: tr
    User-Agent: Mozilla/4.6 [en] (Win XP ; I)
    Cookie: MSPMemberExists=mail@hotmail.com; domain=account.services.passport.net
    Content-Length: 15
    $+(x=,$getdate)
    n/n/
    ;;server bize 4 yanıt yollar
    ;;1st
    Set-Cookie: MSPMemberExists=MemberExists; domain=account.services.passport.net;path=/;version=1
    ;;kullanıcı adı mevcut demektir.
    ;;2nd
    ;Set-Cookie: MSPMemberExists=ForbiddenWord; domain=account.services.passport.net;path=/;version=1
    ;;kullanıcı adı yasaklı bir kelime içeriyor demektir
    ;;3rd
    Set-Cookie: MSPMemberExists=OtherError; domain=account.services.passport.net;path=/;version=1
    ;;kullanıcı adında hata var ise bunu yollar @hotmail.com@ ve $! gibi karakterler içeriyor ise.
    ;;4th..
    Set-Cookie: MSPMemberExists=mail@mail.com; domain=account.services.passport.net;path=/;version=1
    ;;kullanıcı adı kayıt edilebilir ise bunu yollar[/code]
    İyi eğlenceler.
    I wish you bear with me , stay near me a.k.a nukedx
Toplam Hit: 13844 Toplam Mesaj: 1
