linefolder Advenced System Care Pro [İstek]
    kvasir
    kvasir's avatar
    Kayıt Tarihi: 24/Ağustos/2005
    Beyler elinde olupta upload yapabilecek veya link verebilecekler varmıdır crack veya serial i ile ?
    Sigortacı
    DJ_Alper
    DJ_Alper's avatar
    Bilgi/Destek Madalyası
    forumda çok sayıda olmazı lazım geçenlerde vardı bende hatta bende koymuştum gibi hatırlıyom neyse
    bu arada veren olursa serialini girerken hattı kes :)
    ben bunu kurmuştum virüs uyarısı verirse sallama :)
    Quote:
    This easy-to-use and informative application cleans, configures, and optimizes your PC. Advanced WindowsCare Pro's interface dispenses with the bells and whistles to display
    commands and data without embellishment.
    The install Wizard zips through the set up, querying the user on the PC's primary use and Internet connection type. Answer those two simple questions, choose from a short list
    of options, and you're ready to virus check and scan for spyware, registry errors, and start-up problems, or clean your PC of history and surfing traces. The app's strength is
    the detailed information the scan provides, which lists each item with a description of its value based on trustworthiness. Unknown items can be identified online or ignored.
    The Tools menu checks five primary areas of your PC for rogue processes, services, and incorrectly installed options.
    Since registry entries are involved, we wish the fixes recommended were more detailed. The program includes a quick restore point option for system safety, but repairs can't be
    made in the trial edition, drastically circumscribing the app's effectiveness unless you buy it sight unseen. The app's uncomplicated and straightforward usage is appreciated,
    but the since the main selling point has been cut off at the knees, we're hesitant to give this a more glowing recommendation.
    Publisher's Description:
    Quote:
    Advanced SystemCare Pro (formerly Advanced WinodwsCare Professional) provides an always-on, automated, all-in-one PC Healthcare Service with anti-spyware, privacy
    protection, performance tune-ups, and system cleaning capabilities. This powerful and award-winning precision tool fixes stubborn errors, cleans out clutter, optimizes Internet
    and download speeds, ensures personal security, and maintains maximum computer performance automatically.
    Version 3.3.4 improved AutoCare function.
    Tutorial:
    Install normally:
    After installation, open the patch (provided by Pharaoh's team).
    Click patch and locate the .exe of advanced system care pro (by default, it should be in C:\Program Files\Iobit\Advanced System Care 3\)
    This message should be displayed:
    Enter your name in the field below the server check, and click generate.
    Open Advanced System Care and click upgrade:
    Click enter license now:
    Copy your name and serial key from the keygen (exactly as they are) and paste them in the appropriate fields.
    The following message should display:
    After clicking ok, this message should display:
    Don't worry about the error message. Its just normal, as we killed the server check earlier...
    Congrats! Now you've upgraded to Advanced System Care Pro! Enjoy!
    DOWNLOAD:
    Code:
    http://rapidshare.com/files/260421692/Advanced_SystemCare_Pro_v3.3.4.rar
    kerim
    kerim's avatar
    Kayıt Tarihi: 10/Mayıs/2008
    http://www.mayonez.net/tam-surum-programlar/araclar/sistem-araclari/24655-advanced-system-care-professional-v334666-trkze.html
    türkçe.
    Jilet_Boris
    Jilet_Boris's avatar
    Kayıt Tarihi: 04/Mart/2009
    yarın yeni bilgisayara win7 64 bit kurcam xpdeki gibi gereklimidir bu?
    Sigortacı
    DJ_Alper
    DJ_Alper's avatar
    kerim bunu yazdı:
    türkçe.
    zaten kendisinden türkçe desteği var :)
    CyberAngel
    CyberAngel's avatar
    Kayıt Tarihi: 01/Eylül/2008
    Alper öyle bir söyeldin ki şimdi indirecektim vazgeçtim.Ne demek virüs uyarısı verirse sallama ? Benim antivir kasper gibi filozof değil.. birşey öttümü orda vardır birşey.. Neyse ben zaten free olanı kulanıyordum.. pro'nun artıları çokmu fazladır ?
    kvasir
    kvasir's avatar
    CyberAngel bunu yazdı:
    free si resmen saçmalık sadece oyunlardaki belli başlı mavi ekran hatalarını gideriyor, Pro + CCleaner yaptın mı formattan daha güzel oluyor :)
    Sigortacı
    DJ_Alper
    DJ_Alper's avatar
    yüksek performans seçeneğin aktif oluyo :) hoca sallama çünkü bende kullanıyorum sallamadım şahsen :)
    kvasir
    kvasir's avatar
    Çok teşekkürler yükledim halletim, ayrıca sitesinde Game Booster diye program var kullanmanızı tavsiye ediyorum,
Toplam Hit: 1327 Toplam Mesaj: 9
