Guitar Pro 6 Crack ?
    angelofhope
    angelofhope's avatar
    Kayıt Tarihi: 16/Temmuz/2008
    Merhaba arkadaşlar..
    Guitar Pro 6 için crack elinde bulunan varsa paylaşabilirmi ?
    Programming is our Religion, Algorithms are Our Bible & We ./make Our Own GOD
    O Şimdi Astek
    deja-vu
    deja-vu's avatar
    Kayıt Tarihi: 07/Aralık/2007
    http://rapidshare.com/files/401035027/crack-pavka77-GP6.0.1-7840.rar.html
    kolay değil haberin olsun wireless ise internetin daha bi zor..
    içindeki 'readme' de sorun var oyüzden cracklenişini buraya atıyorum
    You will need:
    1. GuitarPro6-r7840.exe - crack does not work with other updates!
    3. Soundbanks - also you can take it from guitar-pro.com/download.php?idfile=gp6soundbanks
    [4.] KLC.Consulting.SMAC.Professional.v2.7.BETA.Incl.Keygen-Lz0.7z - program to change MAC - emergency crack wariant.
    5. guitarpro6-patch.exe - patch if you don't want to change MAC.
    6. reg.reg, GuitarPro6.dat - reg info to register without Arobas server.
    Steps:
    1.  Install GuitarPro6-r7840.exe,should be in the same folder. DO NOT LAUNCH!
    2. Copy GuitarPro.dat
       in XP: c:\Documents and Settings\%Profile%\Application Data\Guitar Pro 6\
       in Vista-7: C:\Users\%Profile%\AppData\Roaming\Guitar Pro 6\
       with replace.
       Create this folder if you don't have it.
    3. Add to registry reg.reg (double click).
    [4.] Open with notepad c:\WINDOWS\system32\drivers\etc\hosts
       Write 127.0.0.1 activation.guitar-pro.com
       Save.
    [5.] Change MAC 00-24-21-1E-AA-99. SMAC 2 is here.
       Consult your SP about ability to change MAC
       INSTEAD OF MAC CHANGE you can try to patch with guitarpro6-patch-Fixed.exe, do not forget to put it in program folder.
       Patch should write "Filesize OK!".
    6. Reboot.
    8. Launch program.
    9. Do not let it to iNet (only allow to 127.0.0.1 activation.guitar-pro.com).
    Program does no recognises any non-latin simbols, so all paths that program uses should be in latin characters.
    In case if program still wants a code try to repeat 2 and 3 steps.
    Or try to create any local connection (not wireless). And make all steps again.
    Kind of combined method from jpac13
    It works now!! here's what I did:
    1. Disconnect wireless and connect with lan;
    2.Install "guitarpro6-r7840" and soundbanks (Don't open GP6 at the end!!!!);
    3.Copy "guitarpro.dat" to:
    C:  Users % Profile%  AppData  Roaming  Guitar Pro 6
    4.Open "reg.reg";
    5.Open with wordpad: c:WINDOWSsystem32driversetchosts and add this line:
    # 127.0.0.1 activation.guitar-pro.com save;
    6.Go to: Control Panel-> Network and Sharing Center-> Change Adapter Settings ->Right click Local area connection->Properties -> Configuration -> Advanced -> Network Address> Write: 0024211EAA99 click ok;
    7.Open Guitar pro 6.exe. (You can reconnect to Wireless)
    Done!
    Almanya Fatihi
    ArmadA
    ArmadA's avatar
    Kayıt Tarihi: 08/Ekim/2005
    çizik
    Living Death
    dyrnade
    dyrnade's avatar
    Kayıt Tarihi: 27/Temmuz/2009
    İngilizce anlatımı anlamayan olursa pm den ulaşsın çevirir atarım 5 dk sonra.bi işe yarıyalım bari forumda:P
Toplam Hit: 5785 Toplam Mesaj: 4
