Sony Vegas Pro Lazım, Yardım
    HighElf
    HighElf's avatar
    Kayıt Tarihi: 19/Aralık/2008
    Arkadaşlar şu anda uğraştığım bir işte sony vegas pro ya ihtiyacım var sürümü fark etmez ama son sürüme ne kadar yakın olursa o kadar makbule geçer 30 günlük deneme sürümü var şu anda bilgisayarda ama bitti bittecek akvite edemiyorum biriniz hayrına serialini crack ini kendisini cartını curtunu upload edip paylaşabilir mi ?
    Çok makbule geçer Vallaha
    Bir Arnavut atasözü der ki: Burri pa arme si gruaja pa breke ! Silahsiz adam donsuz kadin gibidir !
    weskeyy
    weskeyy's avatar
    Bende arıyorum vegas sürüm yeniledim sonuç malum adobe dahil alışamadığım programlarda kayboluyorum alışmak başka sanıyorum.
    BlackStorm
    BlackStorm's avatar
    Kayıt Tarihi: 11/Ocak/2009
    Sony Vegas Pro 11.0 Build 520 (32 & 64-bit) Final - Multilingual - Full
    Incl New Patch & Multikeygen DI v2.0
    New Release: January 19, 2012
    Quote:
    The Vegas Pro 11 collection — Vegas Pro 11, DVD Architect Pro 5.2, and Dolby Digital Professional Encoder — provides an efficient, intuitive and integrated content creation environment for video and broadcast professionals. Now featuring GPU-accelerated performance with OpenCL-supported devices, Vegas Pro 11 powers through video processing and rendering tasks with ease. With innovative stereoscopic 3D tools, broad format support, unparalleled audio control, and GPU-ignited effects processing and rendering, the Vegas Pro 11 collection streamlines your workflow like never before.
    Precise Editing Tools
    Edit SD, HD, or 3D video with drag-and-drop functionality, extensive editing tools, and incomparable video effects. Features include stereoscopic 3D support, multicamera editing, 32-bit floating-point video processing, video stabilization, customizable window layouts, HDV/ AVCHD/ RED/ SDI/ XDCAM/ HDCAM SR support, and A/V synchronization detection and repair.
    Efficient, Professional Workflow for 32- and 64-bit systems
    The Vegas Pro 11 interface provides a fully customizable workspace for accomplishing a wide range of production requirements. Dock multiple windows across multiple monitors and save your layouts to fit specific editing tasks. Nest Vegas Pro projects within the timeline, customize and save keyboard commands, and use application scripting to automate repetitive tasks.
    Broad Format Support
    Vegas Pro 11 software natively supports the newest professional camcorder formats including XDCAM, NXCAM, AVCHD, and RED. Vegas Pro 11 software also includes support for still images greater than one gigapixel in resolution. Use the Pan and Scan tools to create stunning movie sequences from these large pictures while maintaining beautiful HD resolution.
    Superior Audio Control
    Access unlimited audio tracks, 24-bit/192 kHz audio, punch-in recording, 5.1 surround mixing, effects automation, and time compress/expand, while applying customizable, real-time audio effects like EQ, Reverb, Delay, and more. Expand your audio processing and mixing options with supported third-party VST audio plug-ins. Use the Mixing Console for precise audio control.
    NewBlue Titler Pro
    Create 3D titles with Titler Pro, an exceptional new titler from NewBlueFX. Titler Pro enables users to add animations, professional-style templates, and effects to their titles. Work in real-time with GPU-accelerated effects and transitions and easily move text on the X, Y, and Z axes, all within the Vegas Pro 11 workspace. Titler Pro is the perfect addition to the stereoscopic 3D toolset.
    Powerful Blu-ray Disc Authoring
    Burn movies to Blu-ray Disc™ directly from the Vegas Pro 11 timeline for high-definition delivery. Use DVD Architect Pro software (included with the Vegas Pro 11 collection) to author DVDs or Blu-ray Discs with subtitles, multiple languages, and numerous playback menus. Preview and test your work in real time. Apply Brightness and Contrast, Crop, and Anti-Flicker filters. Add high-quality preset backgrounds and themes to add life to any project. Set CSS and Macrovision copy-protection flags for masters..
    GPU Accelerated Performance
    Working with OpenCL supported devices from AMD and NVIDIA, Vegas Pro 11 leverages GPU acceleration for video FX, transitions, compositing, pan/crop, track motion and encoding, providing a significantly faster workflow. The addition of GPU acceleration streamlines the video editing experience in Vegas Po 11 by providing playback performance gains and faster rendering times, ideal for industry professionals who work on tight deadlines where every second counts.
    Stereoscopic 3D editing
    Create breathtaking stereoscopic 3D projects with the same ease and agility as the Vegas Pro 2D workflow. Vegas Pro 11 provides the ability to easily import, adjust, edit, preview, and output stereoscopic 3D media — all using industry-standard professional delivery formats including single or dual files with side-by-side, top/bottom, or line-alternate encoding. Anaglyphic monitoring and output are also supported.
    * Compatible with:
    Windows Vista SP2 (32 and 64-bit)
    Windows 7 (32 and 64-bit)
    * Multilingual: English, Spanish, French, German and Japanese ( 5 Languages )
    Sony Vegas Pro 11.0 Build 520 (32-bit)
    For Windows Vista and Win7 (32 and/or 64-bit)
    Code:
    http://sony-900.vo.llnwd.net/dspcdn/current/vegaspro11.0.520_32bit.exe
    Sony Vegas Pro 11.0 Build 521 (64-bit)
    For Windows Vista and Win7 (64-bit)
    Code:
    http://sony-900.vo.llnwd.net/dspcdn/current/vegaspro11.0.521_64bit.exe
    keygen DI v2.0
    You will be able to activate:
    a) Vegas Pro 11 (32-bit) on Windows (32-bit).
    b) Vegas Pro 11 (64-bit) on Windows (64-bit).
    c) Vegas Pro 11 (32/64-bit) both on Windows (64-bit)
    d) Vegas Pro 11 (32-bit) on Windows (64-bit) -> untested
    Code:
    http://www.mediafire.com/?fdas52vj85xdnco
    http://www40.zippyshare.com/v/11058297/file.html
    Windows 64-bit (additional instructions)
    Code:
    working Windows 7 64bit.
    Install Sony Vegas pro.
    Copy "Shared Plug-Ins" folder from "Program Files (x86) -> "Sony"
    Paste "Shared Plug-Ins" folder to "Program files" -> "Sony" -> "Vegas Pro 11.0
    Run Keygen and select Vegas pro 11 from "Product Name" box.
    Click "Patch" and navigate to "Sony Vegas 11" install directory, then "shared Plug-ins" folder then click "Patch" then it should patch successfully.
    Then Run Vegas Pro 11 and enter serial and authentication codes and all should be accepted, Run Vegas 11 and enjoy.
    That's what i had to do to get it to Patch properly.
    WORKS 100%
    HighElf
    HighElf's avatar
    BlackStorm hemen çekiyorum, kralsın :) birde ne çabuk buldun ya kaynağını da sorarak yüzsüzlük yapayım diyorum :D
    BlackStorm
    BlackStorm's avatar
    HighElf bunu yazdı:
    Estağfurullah hocam ne yüzsüzlüğü :) şuradan buldum:
    http://www.warez-bb.org/
    HighElf
    HighElf's avatar
    keygen fail :(
    BlackStorm
    BlackStorm's avatar
    HighElf bunu yazdı:
    keygen fail :(
    Hocam birisi şöyle yazmış bir bak istersen:
    Okay, just in case anyone still can't get this to work. Once you copy share plug in to the program files folder from the (x86) folder. Open the keygen, choose 11.0 and press patch. Select Sony Vegas 11 folder FOR BOTH of the selections. Don't individualy choose Share plug in, it will poop the bed.
    So again...
    1.Copy Share plug in from Program Files (x86)-- SONY---Share plug in to Program Files---Sony -----Vegas Pro 11.
    2.Copy keygen into Program Files==SONY==Vegas pro
    3. Run keygen
    4.Choose sony vegas 11
    5. press patch
    6.Select Vegas pro 11 folder
    7. It will PROMPT YOU ONE MORE TIME. RE SELECT THE VEGAS FOLDER AGAIN AND NOT THE SHARE PLUG IN FOLDER!!!
    Press ok and wait. DONE
Toplam Hit: 1712 Toplam Mesaj: 7
