linefolder Network - İnternet
linefolder Wifi Sinyalinizi Güçlendirelim(Sadece Resimlere Bakarak Yapabilceginizucuz Güzel Bir Yöntem)
    Mycity
    Mycity's avatar
    Kayıt Tarihi: 01/Şubat/2011
    Images Courtesy of The Chive
    I love a good hack, especially one that requires me to throw back a cold one before hand (or during). This simple wifi boost has actually been shown to increase signal strength by at least 2 to 4 bars. And, well, I will drink to that.
    These instructions came to us via The Chive and we think they are most definitely worth checking out. But here is the most important question: what kind of beer will you use?
    For this project you are going to need scissors, a utility knife, some adhesive putty and an empty beer can. More than one empty beer can is acceptable but don’t kid yourself, the router only needs the one.
    The first step is to wash out your empty beer can, unless of course said beer is a can of Pabst Blue Ribbon. If it is PBR, promptly go drink a better beer. You really should be ashamed of yourself.
    Once the can has dried, you will want to remove it’s pull tab.
    SLIDESHOW: 10 CUTTING-EDGE GADGETS YOU WISH YOU ALREADY OWNED
    Only perform this next step if you have not been drinking. Using the utility knife, saw off the bottom of the can. Chances are your can will not have a red dotted line. If you see one, put down the knife…you’ve had too much beer.
    You’ll notice in the above step that the can’s pull tab has returned. Clearly, there are only two possible reasons for this. One, you are really drunk and you never removed the tab in the first place. Or–the more likely answer–beer cans can regenerate themselves.
    It’s the home stretch! You just need to attach your modded beer can to the wifi router. Hopefully no other parts of the can have actually grown back. You now have beer-fi!
    So, what kind of beer did you use?
    Bazıları sadece konuşur bazıları ise hayalleri ile dünya'ya yön verir.. Mycity
    jon6
    jon6's avatar
    Kayıt Tarihi: 07/Ağustos/2011
    vay çok güzel ve basitmiş, teşekkürler, deneyeceğim.
    CAgAtAy
    CAgAtAy's avatar
    Kayıt Tarihi: 15/Haziran/2008
    sağol hocam kolaymış
    Lider doğru işleri yapar; Yönetici işleri doğru yapar;
    saybirs
    saybirs's avatar
    Kayıt Tarihi: 24/Temmuz/2009
    cizzik
    sokoban
    sokoban's avatar
    Kayıt Tarihi: 23/Ocak/2010
    süper hocam ne kadar güçlendiriyor acaba ?
    Mukavim_
    Mukavim_'s avatar
    Kayıt Tarihi: 29/Temmuz/2003
    Yer İmleri--> Bu sayfayı yer imlerine ekle--> Çizik--> Teşekkürler
    DarkFall
    DarkFall's avatar
    Kayıt Tarihi: 18/Eylül/2007
    modemim kablolu. telefonum var, telefonlar içinde geçerli mi acaba :D
    Nerde o eski TBT...
    Mycity
    Mycity's avatar
    DarkFall bunu yazdı:
    bilmem denemek lazım :D
    jon6
    jon6's avatar
    kutu kola olur de mi ? illa bira kutusu şart mı, işimiz kalmadı bi de alkolik arkadaş aramayalım kutu için
    Mycity
    Mycity's avatar
    pirax bunu yazdı:
    olur olur
    Sigortacı
    DJ_Alper
    DJ_Alper's avatar
    Bilgi/Destek Madalyası
    sen  denedinmi işe yaradımı
Toplam Hit: 8433 Toplam Mesaj: 41
